One of the members here asked if I could post some pics of machine ops on my VW engine build. Don't have a lot of pics, but you'll get a glimpse of the madness. Decking the case with a flycutter I made on the mini lathe and mini mill. The case is about as large a piece as the little mill will hold. Decking the case is done to precisely match cylinder capacity and to ensure cylinder squareness to the crank on all four jugs, and to make certain all four cylinders will have identical capacity. The case is a magnesium alloy, so great care must be taken to avoid burning the house down. The engine has a custom 86mm stroker crank, 92mm jugs, ARP rods, and dual ignition, among other custom parts. Projected HP is ~100 @ 3800rpm. It is built for torque, and will power the airframe I've built over the last 5 years.
to put out.... Heavy foam works ok. In most car fires, even though magnesium is highly reactive to water, we flood the engine bay with 1000's and 1000's of water in just a few minutes. It has to be A LOT of water to put it out, or you'll just make things worse. Water will make a magnesium fire snap crackle and pop! It's highly reactive and will shoot sparks and flames, if enough water/foam isn't used. The foam actually suffocates the fire by covering it with a barrier to block out the oxygen the fire needs as fuel......
Poboy is right, I am dragging my feet on this build. But, building an aircraft that will carry my carcass at 150mph . . . probably not a good idea to rush the build. A lot of research, learning . . . sometimes making a part 3 times to get it just right. No doubt, arrival at the destination will be a great thing, but for me . . . the journey is just as enjoyable.
