r_chez_08
Should be in the shop...
could a mill cutter be used in a pillar drill, as normal drill buts wont easily cut straight through cylinder material, like circle bar/ tube.
You can't mill with a drill press, the chuck wont stay on. You can however use a milling cutter in a drill like manner, for making holes in places a twist bit cannot handle.
good idea.lol i dont see it working well if you want a mill http://www.youtube.com/watch?v=6drMZqmyXQc
there u go
make sure its a center cutting endmill if your are planning on plunge cutting
