mikuni carbs
1992suburban
I wanna go FAST!!
Sanford, NC
I have seen JUST the carb for 40 bux.
they seem to do Ok I have not tried one..
I would assume they allow the engine to turn a lil harder, may sacrifice bottom end on a stock engine.
with an intake adapter, filter, and carb 100 bux..
jr dragster T
Cold place
Mikuni corp makes ALOT of different carburetors ranging from stock EPA carburetors on lawnmowers all the way to 58+ mm slide carbs. The most common sized Mikuni used on a stock GX200 with a stock sized intake valve is typically 22 mm. It is a roundslide carb and works pretty well on these motors.
Gearstix
Alberta, Canada
I was told a flatslide carb will have waay more throttle response. But the roundside seems like it should have decent throttle response aswell.
I got my 22mm Mikuni for free, with a pit bike manifold, and you can mod the pitbike manifold to fit. I just obolonged the holes a bit.
