Mikuni carb 22mm with k and n filter
Jason1213
Usa
Ohhhh
Sent from my SAMSUNG-SM-G900A using Tapatalk
---------- Post added at 07:59 PM ---------- Previous post was at 07:58 PM ----------
I get what do you mean
Jason1213
Usa
I think I should bend the little tube that the throttle cable goes through and make it straight.
Jason1213
Usa
Ohh alright I'll do it tommorow
Your fuel lines are wrong. There's 2 fuel inlets on that petcock meant for on and reserve. Simple. One is taking gas from higher in the tank. When it's out reserve is lower I. The tank and allows the last bit of gas to get your butt home.
The fuel over flow should just drop on the ground.
You have it routed back to the inlet of the petcock.
Jason1213
Usa
Yes I know thank you I fixed that
Jason1213
Usa
Could it be that my throttle cable is to long? Like just by a little bit. The carburatos that it had was different.
How would a long cable be a problem. If it's properly lubed and not in a bind. Now if the spring return doesn't have enough to over come the friction of the cable then that's a problem.
Jason1213
Usa
So your saying the spring could be weak?
---------- Post added at 04:35 PM ---------- Previous post was at 04:33 PM ----------
I'm sorry I don't have to much knowledge with Mikuni style carbs.
