So is it a lawn tractor battery or a motorcycle battery?
All of my neighbors are pretty cool, so far. The gearing is off, with ony 8t on the jackshaft and 54t on the axle sprocket, we are looking at approximately 43 mph at 5500 rpms, which is okay. Id like the max to be 50-55ish as the kart does accelerate too fast as is. I know for sure i will max at 49ish mph with a 9t sprocket (which I had on it originally), and 55 mph with the 10t sprocket. Im comfortable with tthe 9t, but I want to see if i can finagle that 10t in there (it will be a tight fit with a half link if anything).Wait, is this thread renewed??? SAWEEEEEET! It's so creepy to stare at a locked ghost thread... I am MIDAS biggest fan by de way!exhaust is an amazing idea, just apologize to your neighbors afterwards...
I dunno, some junk battery you get on ebay for $10-$15 shipped. I went ahead and got a duracell AGM platinum 180 cranking amps battery over the weekend and will be putting it in.So is it a lawn tractor battery or a motorcycle battery?
Sounds like a heck of a good time.
Breather tube for valve cover is vented to atmosphere, but its chucking a bit of oil on the muffler now. Any ideas/links/advice on what to do?
I tried to take 0.025" off of a head sanding on a pane of glass. It was not fun. I can assure you.
The only fun thing sanding by hand is wood. Just more satisfying. So what did you use instead is sanding it by hand?
