What weight are these things rated @? I like the look but worry about whether or not they stop well. Gonna be on a 100lb cart with a 50-75lb driver. Thanks!
Those would work really well on a kart that weight. I'm using two on my kart but only because there's two axles in the rear for the left and right wheels. They'll lock up your tires real good if you step on them hard enough.
If you have the money I would go with some hydraulic Wilwood disk brake's. I have them in my jr dragster and it will lock up 2 8 inch wide slicks on the VHT sprayed track no probelem.
