Maximum safe RPMs
loneagle
I am wondering what the max safe RPMs are for my Tecumseh snowblower engine? I also need to know how to limit the throttle opening to make it live for awhile? I'm not sure if the governor will still adjust with the way I've hooked up the throttle. Suggestions please!
Russ2251
AZUSA:Powered by LAWN-BOY
Probably between 6 to 7k. No fear of flywheel explosion unless some other mod has been made.
Engine manufacturers take into account that governor failure is a real possibility and purposely "over build" them. They don't want customers to be injured or possibly killed.
No stock engine has unlimited rpm's.
An undersized venturi is one way of limiting top end speeds. This is true of all unmodified 'all purpose' engines.
Nothing to fear if governor is not used, as long as nothing else has been changed/modified and engine is used under a load when excessive rpm's are encountered.
Loads are really good at smoothing out combustion pulses.
oscaryu1
Is that really true? A Clone with just the governor removed can hit 5300RPM-5900RPM before the valves float. I recently read up where a flywheel shattered at 5700RPM...
But then again, China doesn't have quality control...
loneagle
Thanks, Russ! Another very informative post. You're a great asset here.
Sorry, but I prefer not to buy the Chinese stuff. I go out of my way to avoid it!
Kenny_McCormic
Kartless....
Michigan Troll
Thats china. Gov failure DOES happen, 30 some odd year old 8hp briggs log splitter decided to lose a linkage one day BRAAAAAAAAAAAAAAAAP!, SHUT IT DOWN!!!!!!!.
Russ2251
Yup, and some folks have been abducted and probed by aliens. It must be true because I read it somewhere. Believe nothing of what you hear and...you know the rest.
Only once have I witnessed a flywheel explosion. It was because flywheel was heavily modified and was then able to reach/pass its terminal rpm. Could also have been due to improper torquing.
An ungoverned engine running at full speed and no load is much more dangerous than the same engine with a load.
Loneagle will not have a problem. He will never achieve red line rpms with his application, governed or not. Same goes for most engines out there.
oscaryu1
I recently read where a CLONE flywheel shattered at 5700RPM...
