wboldrusty70
Mal, I'll get a photo ASAP. Works well on my C model, which has the coil under the flywheel. Does the D model feature the external coil?
Bill
Bill
My friends is a D model i think. Has magneto thingy on outside with a wire running under the flywheel so i assume it has points etc under there. Havn't had the flywheel off yet though.
Hi again, Attached are photos of the Victa module as fitted to my C model engine. Installation is easy, just find a good place to put the module and attach the wires to the terminal that otherwise go to the points. Do not include the condenser (capacitor) in this connection. As long as the module is well earthed, it is not critical where it goes. Hide it somewhere so that only you know of the deception!!!!
Keep the old ones going. Bill
Pleased the photos worked this time.
The module is from a powertorque engine, which has been the same one since the inception of this engine, until they changed to the integral unit a couple of years ago. If they work, they work, or they have failed, That is the only test I know of for modules. I think they are still available in Aus, at a price of about $A30.00.
