That wasn't directed at you hack; if you want to use square tube, go for it. Round tube may be a little cheaper but, it's also more work...
Like I said need to do some research. There are many options out there, mostly depends on what you want and have to spend.
Bicycle gearing will not do for a typical kart. It will destroy itself quickly. Even with motorized bicycles, they are not powered into the the bikes gearing.
Im assuming your using a clone type engine.
Oh.. do a dry test without an engine to try, I assume you will shred the derailleur with a go kart chain (and the speed and torque it's moving)
Bicycle sprockets for that type have slightly angled teeth, kart sprockets don't
I assume changing gear to a larger sprocket will also lock the chain.
shifting up (down into a smaller sprocket) should work though.
please make sure it's working on the chain and sprockets you intend to use WITHOUT an engine attached to the system;
this way you will have no chain trying to attack your eyeballs
