Oh and the comments were all good but i think i found the real reason why my steering sucks so bad. Its the cheap, stock hiem joints. When i pulled then off the looked worn out bad. And since I'm beefing up the suspension i might as well do the same for the steering linkage.
I would like to fix my engine so that it is in a higher position and i don't want it mounted to the swing arm. Can anyone point me in the right direction?
I just love how people only check out new threads. Guess that is just the way it is here. Anyway, for anyone still reading, i got my rack and pinion today, as well as the universal joint steering shaft. I plan on riding this weekend. I'll post pictures when its done
Thank you. Another question. I can't find the specs for mounting the rack and pinion. It seems like it is supposed to be offset a little. I just don't want to end up being able to turn more one way than the other. Oh, its for a yerf dog spider box
Ok, it has been a while, i should have all the parts needed to finish my front end some time this week. But i have a question. For now i am going to keep the rear swing arm, but i would like to fix my engine so that it is in a higher position and i don't want it mounted to the swing arm. Can anyone point me in the right direction?
That comes under the heading of Occam's Razor (the simplest answer is often the correct one) & leave it to a woman to come up with the simple answer; for some reason the male gender tends to overlook the obvious most of the time...
