manco project
Bluethunder3320
i dont know what model number or whatever it is... but theres a sticker i should go check out.
well the TC is not on it anymore and its got a clutch that has a max torque drum modified onto a hillard sprocket.
fixed the brakes.
well i got a throttle hooked up and rode it a while. then the chain broke at the master link. so ill remove it.
the-cyborg
Spring, Texas
Looks good so far, do what you like, but I would recommend going to a TC verses a straight centrifugal clutch, I personally think you'll put allot of strain on that clutch with those tires, and would be wasting the potential power that thing would have to offer.
Bluethunder3320
true, but i put the TC on my mini bike, and dont have enough money for a new one.
i got this together for free so its a win!
DaiSan76
Nixa, MO
Is it my imagination, or does that sprocket hub have a giant hole of death and destruction in the middle of it?
Bluethunder3320
had a problem with the keystock. its not a normal key. its the same width but alot deeper. so i had to put in one normal key, and one half ground key ontop of it to keep the first key pressed down.
im debating welding the keystock into the axle. the axle is so crapped out anyways. (very bent) so when you go fast it bounces the kart haha.
DaiSan76
Nixa, MO
I see, I was talking about the other side of the axle where all the grime is cleaned off, the color of the metal matches the dirt, and it looked like there was a huge chunk missing out of the hub. I looked closer this morning and see that is it just clean metal. :roflol:
Bluethunder3320
one heluva exhaust on that. is it supported?
its surprisingly no heavier than a stock muffler pretty much.
its off a 13.5 briggs.
bringing this to a party saturday with 36 people so it should be fun :thumbsup:
its at my friends house for now (his engine)
more pics
throttle set up. (just like i did to my mini bike)
oh yeah the axle is bent ALOT now cause my friend hit a curb hard. :ack2: ill get a video up of the tires spinning on the bench. theres about an inch of movement.
B man
Tecumseh FTW!
Oliver springs,Tn
your friend sucks at driving.lol but if i where you i would take it off heat it up and bend it back as best you can.
Bluethunder3320
yea i need a torch.... haha.
EDIT: sooooo my friend just broke the pull start. but he made a second knot in the handle and he said its fixed.... at least it kinda works
redsox985
PA
Your friend is burning a hole in your pocket quite fast. I'd be upset. :p
Blazkowiez
Kart Aficionado
Houston, Texas
They do offer large sprockets so you can run chain drive on that veri-hub. They are offered through Azusa I believe. Check them out. It'll solve all your problems and should cost around 32.50.
Bluethunder3320
wow it has been a while since i updated this.... a couple people have owned it after me and its seen better days... lol
got a new torque converter a year ago? i think.
every time its ridden it breaks
someone straightened out the axle
its been run into multiple trees and one of the tie rods was twisted around so bad that it wouldnt steer at all.. wheels were pointed like a triangle. and they kept riding it like that and blew the tires. but they still rode it after that.
the throttle is a ratchet strap
im helping him fix it up and started off by fixing the spindles. heated them up red hot and bent them back straight. i thought about reinforcing them but im too lazy.
also made a straight pipe today it looks nice. ill get pics up later
Didn't you have this problem with a minibike you were trying to sell?
Seriously- where do you find these idiots? Does your For Sale ad read, "Looking for a Darwinian candidate to attempt to destroy himself and a cool motorized toy"?
I do hope you're charging for this...
Bluethunder3320
yeah i got real bad luck with these things :roflol:
the kid who owns it now is a good friend. i fixed the spindles in school cause i had nothing better to do
as far as i know it needs new sprockets, theres no teeth on the drive sprocket
if it was mine id tear it down and rebuild it with a bike engine, bigger tires, more ground clearance, maybe some off road lights
