I'm a little concearned about the articulating side of the band 'walking' over left or right off center from the drum. I was thinking about adding a guide on the top so it didn't creep to one side or the other.
I think, especially in this case, that's a real concern. Looking closely at pic 3, you can see that the band is already at a different angle to the drum; that comes down to the mountings which, IMO, aren't the best. Not trying to dis your work but, it could use some improvements:
1. The stack of washers may cause a problem, you're
much better off with a solid spacer (which is not too difficult to make)
2. By tapping the top of the mounting tab towards the drum, it will force the band over at the bottom; not too much, you don't want to overdo it...
3. The actuation linkage appears to also be at an angle in the wrong direction. Again, by twisting it in the opposite direction, you will force tha band onto the drum
