Well dont panic too much. cut off the welds on the motor plate with a cutting disc, flip it around. Check for clearance and reweld. You might have to rotate the cvt about facing under the exhaust port.
So I guess I got really lucky, I turned the motor around just for the hell of it. Guess what...it fits even better backwards!!
I had a little difficulty with the jackshaft washer mounts...they were twice as thick as my tubing, so I cranked up my Hobart 190 to 60 on the feed and 5 on the amperage to cut into the washers, but when I got near the tubing, I could feel it almost going through.
I think the welds are strong enough, but I'm not satisfied with the technique of welding dissimilar thickness metals. any ideas?
well, I spent a lot of time "eyeballing" it...tacking and re-tacking. I tried to square everything up against the axle itself. I think it's pretty good (I did use a tape measure lol)
One major problem I found is that the axle is fixed, and this jackshaft setup is now fixed as well...don't know how to adjust final chain...just remove a link? wont stretch THAT much...
One more question...any input on placing the drive sprocket on the far right side, and having the drum brake on the far LEFT side?
I suppose i may get more twisting moment out of the axle when the two forces oppose across the length of the axle, vs if the sprocket and brake drum were only a few inches apart.
you should be using pillow block bearings to hold your jackshaft, not some washers. the holes in the washers are going to get worn out of shape really fast, and the whole jackshaft is gonna wobble.
unless theres something im not understanding here.
It's a jackshaft kit from BMI karts. They are very beefy large washers with bearing inserts.
http://www.bmikarts.com/Jackshaft-Kit-for-Mini-Bike-or-Go-Kart_p_1048.html
and...oah lah! (easier said than spelled lol!)
Actually, it's voila. It's a french word that literally means "look at that"![]()
