Manco 5HP Fun Power problems
Me three. They vibrated that much I lost one. Loctite fixed it.
Then the carb bolts on the block came loose. Surprisingly, it still ran ok :huh:
MARGR4V3Z
MICHIGAN
i would just clean the pick up tube with a air compressor, then hammer it with a nail on top to open up the top of the tube and jam it into the bottom of the carb. then take out the carb to tank bolts out and put loctite on every bolt and buy or make a carb to tank gasket if yours looks worn or torn.I had the same problem and it is caused by an air leak in the carb, the vibration from the motor can loosen the carb to tank bolts and cause and air leak. loctite keeps the bolts in place , tightly to prevent any air leaks.
How does the pickup tube come off the carb? Since its pressed in there. Could I make the gaskets out of cereal boxes?
Blazkowiez
Kart Aficionado
Houston, Texas
Guys... gaskets for this engine cost less than a dollar. ANY local lawnmower shop will have them in stock. Use the right gasket and the right bolts and you'll be fine.
MARGR4V3Z
MICHIGAN
I wish Gaskets cost that much. The last tank to carb gasket I got was 3.99 and the Diaphragm was 3.99. Also would it be good to stack 2 tank to carb gaskets?
tundrabeagle3
Ca
I bought a roll of the rubber gasket material from autozone for 8.00 bucks and can make at least 15 gaskets out of it. Its alot better quality material than the gaskets they give you at the lawn mower shop and much cheaper as well. The lawnmower shop gaskets fall apart when you tighten them down too much and usually cant be reused.
