Me three. They vibrated that much I lost one. Loctite fixed it.
Then the carb bolts on the block came loose. Surprisingly, it still ran ok
i would just clean the pick up tube with a air compressor, then hammer it with a nail on top to open up the top of the tube and jam it into the bottom of the carb. then take out the carb to tank bolts out and put loctite on every bolt and buy or make a carb to tank gasket if yours looks worn or torn.I had the same problem and it is caused by an air leak in the carb, the vibration from the motor can loosen the carb to tank bolts and cause and air leak. loctite keeps the bolts in place , tightly to prevent any air leaks.
Guys... gaskets for this engine cost less than a dollar. ANY local lawnmower shop will have them in stock. Use the right gasket and the right bolts and you'll be fine.
