r_chez_08
Should be in the shop...
There is a brass mixture screw on the carb. There is also an idle jet and main jet but they require drilling.
The old plug looked like the carbon one but it was loaded with carbon and everything was gunked up and the plug was plugged so it wouldnt fire. The new one was a blacky color and the plug was also wet. So how do I make it run leaner? Where is this screw im suppose to adjust?
it sounds like rings, blueish smoke says its burning oil, loss of power says take a look at your rings, and a carbon fouled plug sounds like stuff burning thats not supposed to. i say try a leak down test
Personally I think you are too rich. When you throttle it you flood it put I guess.
I would try a stock main jet. I am surprised you don't have that mixture screw. What is there instead?
What does it idle like?
A leakdown test would tell us whether it is truly a compression/oil problem. You could also take the head off and check the valve guides.
My clone, straight after a rebuild smoked. I am in the process of rebuilding again. I think it was the rings because the end gap was massive. Before the rebuild it didn't smoke, so the rings went pretty quick. They were upside down, but that wouldnt have made all the difference.
