Before drillin' the holes for mountin' & wirin', I double checked/made sure that the speed controller would not intrude into the "battery box" area
…& also, did a bit of scrollin' on the back of the SC
Added some rubber grommets
…then, simply "poked" the plugs/wires thru
…hooked 'er on the top
…& finally, added a screw to secure it to the kart
It's a good-n-solid mounting
…& the "plate" that it's mounted to, will also act as a "heat sink" to help dissipate any excess heat
