Lunar Rover (prototype)
Lightening brake parts
To help lighten things up a bit, I added some "stylish" holes to the side of the brake pedal
...& also to the connecting/push rod :thumbsup:
Also, added a couple of "stylishly lightened" gussets to the lower mid frame connection :2guns:
PullHorse
Do you sharpen your drill bits or just replace them? So many holes drilled! Looks really great.
Thanks, fellas! :thumbsup:
I've never had much luck sharpening drill bits
...unless it was used for wood or plastic (just for a cleaner hole) :cheers2:
...but, not metal
Harbor Freight is my friend :cool:
The trick, I've learned, when using drill bits & even hole saws when working with metal is to
…keep the speed down (speed creates heat, heat "kills" drill bits :huh:
…& using some cutting oil is very helpful with the bigger bits & hole saws :2guns:
Throttle Pedal Mounting Plate
I made up, aligned & welded on, a good-n-solid mounting plate for the throttle pedal :thumbsup:
Just had to make sure the bolt holes lined up with the "openings" in the floor board :cheers2:
Well, most of 'em do :2guns:
Power System Monitor
I've been thinkin' about "how to" monitor the power systems on the Rover
A PZEM-051 DC Digital Multi-function Meter should do the trick :thumbsup:
http://www.diygokarts.com/vb/showthread.php?t=42102
This will provide the Astro-driver with info on
...the Voltage (V) Voltage of the Battery pack
...the Current (A) Amps being drawn from the battery
...the Power (W) Wattage of the component drawing power
…& also, the Energy (Wh) Battery pack capacity :cheers2:
I was also thinkin' that I want to mount this meter into some kind of a "box" :idea2:
...instead of just on or into the dash board
I have an old/non-working Tom Tom GPS
...that I think, I can maybe "gut" & then, mount this meter into
After disassembly, I used the GPS "screen" as a template to make a "replacement", out of some plastic
…& then, made a cut-out in the "replacement plastic screen", for the PZEM-051 meter :cool:
Yup, that should do it! :2guns:
Next, I used the "cut-out" in the "replacement plastic screen" as a template to mark where the meter needs to extend thru, the back of the GPS "shell" :thumbsup:
...& then, did some whittlin' to get the back to fit on/around the meter :cheers2:
* Notice the before (GPS) & after (PZEM-051 meter) pic :2guns:
...maybe a hint of things to come ;)
Gettin' back to the chassis :thumbsup:
I installed some "front teeth" (OK I think that's enough "metal") let's move on :rolleyes:
We've had a few nice days so, I took 'er outside
...& done some/lots more "cleanin' up" too (deburrin', smoothin' & sandin'):cheers2:
Primed Chassis
A Nice sunny ~70* day for early April & I put 'er to good use :thumbsup:
After a final "go over" (actually a couple of "go overs") I gave the chassis a "bath" (good wipe down)
...with/in some paint thinner :cheers2:
Since, it was mostly "bare" metal, I used some (white) Clean Metal Primer to seal 'er up :2guns:
I figured the tail needed a couple of gussets
...thoughtfully lightened
…& then, strategically placed :thumbsup:
First, I worked on a gusset plate for the upper junction :cheers2:
So, I measured. marked & cut out a piece of metal
...gave 'er a custom curve
…& then, added some stylish holes :2guns:
I made a couple of smaller gussets out of the same material :thumbsup:
…& then, added some "stylish" holes in them too :cheers2:
Clamped 'em in place
…& welded 'em on
* For a "cleaner look" I welded 'em on from the back side
**Notice the "bluing"?
Those are "heat marks" that show/indicates that the welds got some decent "penetration" :2guns:
Rear Motor Mount Plate
To mount the rear motor I found/am using a piece of 1/8" steel ~4" wide, that has a ~1/2" "lip" running along each side :thumbsup:
...one side is bent up & the other side is bent downward
It should be "good-n-rigid" but, still kinda light weight
...may add some "stylish" holes to make 'er even lighter :cheers2:
First. I had to assemble the axle, bearings, sprocket & wheels
…& then, assemble/arrange/align the mount, motor, sprocket & chain
Centered the motor in the frame (kinda like the front motor is)
...aligned the motor & chain
…& marked where the motor mounting holes need to be
Then, took 'er over to the drill press & did some drillin' & machinin'
…'til the "square" under the head of 5/16" carriage bolts slide smoothly in the slots :2guns:
Brianator
Gettin' er done!
Barrie, Ontario, Canada
At the risk of being "that guy" I have to ask.... why haven't you entered this into the build off? With the progress you're making you'd easily make the deadline, just sayin'.
Thanks fellas :thumbsup:
...just doin my thing :cool:
My left brain has been workin' on... :rolleyes:
...maybe I'll enter my next project :stir:
So, after tac-in' the motor mount, in place, I reassembled everything on the tail (again) :popcorn:
...just to double check
Yup, looks pretty good :2guns:
Then, welded 'er on good
...from up underneath, for a cleaner look :cheers2:
Made in USA
While cleanin' up the tail, I had a "vision" :thumbsup:
...well, maybe more like an idea :cool:
...but, it was kinda like I could actually "see it", when the idea "struck"
He...He, I said struck :smiley_omg:
So, I used my 1/4" steel stamper set to "mark" 'er
...made in USA
...or property of USA :cheers2:
I centered & punched the "S" first
...then evenly spaced & punched the "U" & the "A" :2guns:
Primin' the Tail
After lots & lots of clean up :huh:
…& then, a bath in some paint thinner :cheers2:
I got the tail sealed up/primed :thumbsup:
