Lunar Rover (prototype)
The connections, on the front steering cross-bar, are currently ~3 1/2" from the center
...but, I can easily add holes & adjust the connections to the 2 1/2" or 1 1/2" marks
Moving on, I cut a piece of steel for an upper seatback mounting bracket :thumbsup:
...added seat mounting holes
...bending relief holes
...& also, a couple of bigger holes to look kool & reduce weight a bit :cheers2:
...then, bent 'er into shape :2guns:
Next, I cut a custom base/foundation for our seat back & bottom, outta some 1/2" plywood :thumbsup:
Shaped 'em to kinda match the frame :2guns:
I made sure the seat base, mounting bar, sat nice-n-flush
…& the steering cables clear nicely as well :cheers2:
Gotta round up some upholstery
...to give 'er a protective cover & some paddin' :thumbsup:
Until then...
I cut, bent up & installed a couple of bars
...these will act as protective barriers between the astro-drivers feet & the front wheels :cheers2:
...…& also, to "tie together" & strengthen the (2) tiers (upper & lower) of the front end :2guns:
I'ma thinkin' we'll work on the front "drive unit" next
...set up, test etc.
She'll basically be a front wheel drive kart
...but, just for a minute :thumbsup:
I thought about settin' the front up with "dual compatibility"
...so, either a live axle or a diff could be installed.
...but, ran into some issues
The sprocket on a live axle can be adjusted almost infinitely, not so much on a diff :huh:
I have a peerless differential, out of a riding mower, that I used for measurement purposes.
...but, with the diff centered, in the frame & the sprockets aligned, the back of the motor would intrude into the operators foot area a bit. (~1 1/2") :ack2:
So, live axle "it is" :cheers2:
...maybe we'll put a diff on the "tail" to aid steering/maneuverability :2guns:
Front Motor Mount
I cut a piece of 10g. steel to use as a motor mount (it's a bit thicker than 1/8" steel which is ~12g.)
…added (4) adjustment slots
…& then, clamped 'er to the upright bars, right behind the axle/sprocket :thumbsup:
* Used a straight edge to align the sprockets
First, I tried a 60T sprocket
…there was ~2" of clearance from the front bumper/bars
Then, tried a 72T sprocket
…& there was ~1 1/4" of clearance
** The 60T sprocket will make 'er faster :2guns:
...but, the 72T sprocket will give 'er more torque :cheers2:
Ima gonna go with more torque, for now (better for climbin' outta craters-n-such) :cool:
...but, can always switch 'em later (like for racin' with/against alien rovers/karts) :wai:
Floor Boards
I tac welded the motor mount plate in place
…& then re-installed/assembled the axle, sprocket, motor & chain
(just to be sure it's where it needs to be before weldin' 'er down good-n- permanent)
Yup, looks good :thumbsup:
Next, I moved on to the floor boards
...which I'm also gonna try to incorporate the axle/chain guard into as well :cheers2:
So, I measured, marked, cut & bent a piece of expanded steel
...but, when I tried a "test fit", it just seems like too much (kinda overbuilt) :huh:
Now, I'm workin' on something a bit smaller
...more to come :2guns:
Floor boards 2.0
I came up with some smaller floorboards :thumbsup:
...but, the actual floor/foot space did not decrease
They go across/under the foot area
...then, rise's up @ ~45*
…then, level out
…& finally tucks up under the front bearing bracket stress plates :cheers2:
Gives a nice-n-clean look
...& also, isolates the rotating shaft from the foot/pedal area :2guns:
Before I can make/install the left floor board, we gotta work on the braking system :thumbsup:
First, we have to establish
...what type of brake system
...how it's gonna function
…& where & how it's gonna be mounted
Then, make a brake pedal
...& figure where it needs to be mounted :cheers2:
Well, it looks like it would be simplest to just mount a drum brake
...right in front of where the brake pedal, will be
…& have it actuated directly, by the pedal, via a short metal bar :2guns:
* It would put a whole new meaning to "Stompin' on the Brakes" :lolgoku:
So, to mount the "pivot side" of the brake band to the frame, I used a 3/8" "long nut" on the frame side, of the brake drum
…& made up a bracket to support the "inner" side
Made sure everything was square, with the axle & then, tacked 'em on
Now, I am gonna make up a brake pedal
…& a "connecting rod"
…& then, do some testin' (to see if/how well it functions/works) :wai:
Brake Pedal
I rounded up some steel that seemed like it would make for a good pedal :thumbsup:
…& then, made up a simple U-bracket, for mounting it to the kart
Looks pretty good, paired with the throttle pedal :2guns:
Brake Pedal Connecting Rod
I measured, marked, cut, & drilled a piece of 1/8" x 1" steel to use for the brake connecting rod
(it's pretty simple so, I forgot to take pics) :mad2:
But then, when I connected everything together & gave 'er a try
...the brake band kept floppin' around :huh:
…& also, droppin' down/out of alignment with the brake drum :ack2:
So, it looked like, maybe, a set of "sliding brake band retainers" may help :thumbsup:
These retainers don't need to be so Heavy Duty so, I'll just make 'em out of some 1/16" steel :cheers2:
I'll make them both simultaneously, right next to each other
Started off by measuring, marking, drilling, cutting, slotting & some filing too
Not bad so far :2guns:
Next I had to cut 'em apart
…& then, clean 'em up :thumbsup:
Brake Band Assembly with Sliding Retainers
Pics of the sliding retainers, mounted onto the brake band
...with the connecting rod :thumbsup:
Brake Assembly Testing
I installed the brake band assy. around the axle
...& mounted onto the kart
Clamped the pedal down directly across from
...& "in line" with the throttle pedal
Connected 'em together with the connecting rod
Then, gave 'er a try :cheers2:
I tried (3) different connecting points on the pedal
...the middle one seemed to work the best :thumbsup:
Well, it works/functions
...but, still needs some adjustin' :huh:
So far, I'm likin' it :wai:
...short sweet & to the point :2guns:
The first government issued brake band bracket (part # 100007062.79627-2.01) has been recalled :ack2:
...it just didn't meet specs for an "other world explorer" :huh:
So, I've been workin' on installing the new "approved"
...& "improved" brake band bracket (part # 60279LR201.63B) on the Rover :thumbsup:
This "updated" version is a lot lighter
...& looks like it's more/better engineered too :2guns:
Left floor board
The left floorboard has to work with/around the brake assembly, which makes it a bit more complicated
So, I made a template out of a piece of cardboard first, to help work out the fine 'er details :thumbsup:
Then, re-assembled the pedal assembly, to make sure everything "clears" & still functions properly :wai:
Looks good to me :2guns:
Making the floorboard, out of expanded steel, was pretty simple using the template :thumbsup:
Cut 'er out, lined 'er up, clamped 'er down & welded 'er on :cheers2:
Pretty & sturdy :2guns:
These floor boards will provide some protection :thumbsup:
…& won't pick up any "moon rocks" :wai:
Got a couple more pics :2guns:
I think were gonna need something a bit "meaner" than turf savers, for climbin' outta craters-n-such :cool:
Like some really "grippy" tires :thumbsup:
...really really grippy :cheers2:
…even super grippy :wai:
Yup, I think these Carlisle X-Trac (15 x 5.00 - 6) should work :bannana:
Picked 'em up from Surplus Center for ~$50.00 per pair :smiley_omg:
...can't beat (4) brand new rims & tires for ~$100.00 :sifone:
Um, I mean "Government Issued"
...yea, yea, their from the "Government" Surplus Center
Here's how these X-Trac's look on the front of the kart :thumbsup:
Um...Corona wheels :ack2:
After lots & lots of clean up, I re-mounted the axle & brake assemblies
…aligned & tested the brake system
...covered & protected everything
…& then, got the brake pedal mounting bracket welded on :thumbsup:
