Does anybody know why I would not be able to reach the 45 miles per hour? I’m not expecting too I’m just curious. Is it because of a low torque or horsepower of the engine?
Need a bigger, or modified engine.
The powerband of the gx200 is like 2k RPM peak torque and say 4k RPM peak HP. When the kart is geared for the amount of torque the engine puts out, you'll run out of power before the RPMs get high enough to reach 45mph. The power needed to accelerate any further becomes more than than the engine and gearing are providing the axle. The engine HP drops as RPMs increase past the Peak, as friction and drag are increasing on the chassis. Just not making enough power at those high RPMs to continue to accelerate the kart with that gearing.
Shifting the powerband to higher RPMs will help give you the power where you need it. With a Bigger Carb, performance cam, advanced ignition timing, high stall Driver Clutch,... you can the shift power band to like 4k RPM peak torque, 6000 RPM peak HP, and it will spin out to like 7000 RPM.
60T:12T with TC ... 46mph at 7000 RPM
Gearing so 44mph is at 4k RPM (Peak HP stockish engine) Means Running 36T:12T with the TC. That means you are probably going to burn up belts. Acceleration will be much slower and it might take forever to get up to speed, IF you ever get there. Might never shift into overdrive. Because the engine doesn't make enough torque to run that ratio.
A larger engine will have more torque so it can run a faster gear ratio. So maybe a 390cc could handle 36:12 with a TC and 10" tires.
44mph at 4500RPM.
I'm sure ^ is not very clear, but that's how my brain works.
BTW... This is all based of anecdotal evidence. I don't have a small kart. I've never had 10" Tires. This is blurry and hand-wavy math where I mentally weigh whether a kart will accelerate or not.
You might be able to run 48:12 with TC and 10" tires and turn 5500 RPM with stock springs. That would give you 45mph. Not sure you'll have the power with a stock engine. Not 100% sure you won't. Valve float normally happens around 5200-5500ish RPMs with stock springs, IF you have the power and gearing to reach valve float RPMs.
All that without a pic or mention of weight.
I need a nap now.
