Lift rollers
Finally done machinin' :mad2:
Tray 'o parts
Assembled (bolted thru the rollers & also, clamped with vise grips) for weldin'
* Notice I included a washer?
It's so, I could bolt everything together good-n-tight, for weldin'
...then, I'll leave the washers out during final assembly
...so, the rollers can "spin freely" :2guns:
Ready, set, welded
View attachment 148281Close up, of the weld
Close up of it cleaned up
I must say "not bad" for a little HF unit :2guns:
The gangs all here :wai:
Weldin' tip of the day:
Besides your weldin' gloves, wear a "sleeve" of some kind (even in summer) to help protect your arm(s)
I use a cut-off "leg" section of an old pair of Denim pants, as a quick on/quick off sleeve :cornut:
...& it's kinda stylish too
I just put my hood on and raw dog it. I have the gear, I just don't bother beyond the hood unless I'm welding overhead and underneath like an exhaust system (which I hate doing immensely).
After weldin' & some clean up, I had ta do some trimmin'
...'cause (1) side is longer/taller than the other
...& extends higher than the roller
* It should look like the close end not the further away end ;)
So, I put 'em "back to back" (tall side & shorter side)
...used the roller bolt holes to help with alignment
...& clamped 'em (w/vise grips) for trimmin'
Now they B even :2guns:
...& NOT extend higher than the roller :thumbsup:
Probably would have ta make a steel "backer"
...so, the teflon block didn't " de-form around the curved mount, on the truck
Counter sink the bolts
...still a "back up plan
Nuthin wrong with the current plan. Nice work as usual.
l’m not only cheap, but i’m lazy as well. I look for anything
that reduces actual work.As my bride reminds me often “yer a lazy cheap slob”.
i just need ya give ya some shyt!
Work smarter not harder
Your not enjoying following along with my project?
While the paint was drying, I went & got some "hardware"
Good-n-strong
Never-seize time ;)
* I got some disposable gloves
...'cause this sh*t get everywhere :ack2:
Yup, this stuff
Slathered it inside of the rollers
...& on the bolts too
Then, put 'em together
See, I got quite a bit on me too :huh:
Sub-assemblies are now ready for installation :sifone:
Hey T,
Well, a couple of weeks ago, upon routine inspection, I noticed the right, rear roller unit was kinda twisted
Seems (1) of the 3/8" x 1" grade 8 bolts broke
So, I re-aligned the unit
...& replaced the bolt
Since then, they seem to be doin' good
...but, I'm still keepin' my eye on them :thumbsup:
