Lift rollers
I'va been thinkin' about makin' some "rolling lifters" for my flatbed tow truck
...outta some steel rod
...& some angle iron
So, I rounded up a piece of 1" steel rod
I marked it in 3" sections
...then, wrapped some masking tape around the rod
...to "highlight" the cut line
...& to help ensure an even cut
I used a cut-off wheel on the grinder
...periodically spun the piece, while cuttin'
...& it turned out kinda like this ;)
Please 'splain. Wadda they do, besides roll and lift?
Hey T,
Sorry for the delay (had ta work at my "day job") ;)
Back story:
I wanted to add ~1' of lift, to the rear of my flatbed tow truck
So, I installed some 1" (thick) x 3" x 3" solid steel "blocks" to the helper spring "perches" (I guess ya call 'em)
But, the lateral movement of the springs seems ta be "workin' 'em loose"
...& I ended up loosing (1) :ack2:
So, I temporarily installed a 1" thick x 3" x 4" piece of Oak, until I could get a replacement
Simply secured, in place, with a couple of 3/4" drywall screws
...& I added some grease in between the "spacers" & the springs, ta help "lubricate" the situation :cheers2:
But/then, the next day, another one went AWOL :eek:
So, now I'ma thinkin' that I need some "lifts" that'll "roll" :sifone:
Id just flip the rear shackle so the spring is is below the pivot bushing instead of above, the replace the the overload spring saddle bushings with those of the appropriate hight.
Overload springs (aka helper springs🙄) aren't even supposed to touch anything until you have reached the point the mainsprings have began to sag X amount under load at which point depending on the vehicle the contact a padded saddle or the frame rail itself with a heavy bushing on the leaf ends instead.
That metal on metal bullshıt is not the answer and is going to do little more than one hell of a racket
So you are talking about “self aligning cylinderical spring rate enhancers”?
what gunna keep (dem doggies ) roll’in?
Hey T,
That is quite the fancy name
...but, I guess "if" ya wanna call 'em that :thumbsup:
Roller Brackets
I'ma gonna use a (2) piece design for the roller brackets
...'cause I don't have the equipment ta bend steel this thick/heavy duty
* Notice we have (2) different brackets
...with the roller "axle" holes on (2) different "planes"
So, when the brackets (left & right) are "stacked" the "axle" for the rollers will be horizontal
Still lots more work ta do (those are only 1/4" "axle" bolts)
...but, I'ma thinkin' we gonna need at least 1/2" "axle" bolts
Something like this is what I have in mind :sifone:
I doubled 'em up to help spread the "load" ;)
Another view
how are you managing to drill, dem rollers on center all the way through?
Had ta do some DIY sh*t
...& it's a "work in progress" :cheers2:
First, I just tried measuring, marking, punching
...but, the results seemed kinda "iffy" :eek:
So, then I used a DIY center'er :thumbsup:
Which is a 1" x 1/4" slug, from some other project
Next, I drilled a 1" hole, in a piece of 1 1/2" MDF
...& "popped" the "slug" in
...for drilling/marking the center
Then, just inserted a roller from the bottom
...& used the "slug"
...& a 1/4" drill bit
...ta "start" the hole(s) ;)
Before
After :2guns:
Hey Rat,
Thanks for the input :cheers2:
...but, I'd be leary about changing the design of the suspension
...the spring/shackles weren't designed to "work like that"
...& also, looks like that concept would provide too much "lift" (maybe ~3" - 4")
My idea is to not try-n-re-design the suspension
...but, to simply add a 1" "spacer"
...to "trick" the springs into thinking the "roller lifters" are just part of the existing spring helper perches ;)
This truck has a 14,500 GVW
...it rides good & carries weight well
But, when I tow (lets say) an old Caddy (2 - 2 1/2 tons or 4,000lbs - 5,000lbs.) or even a newer Escalade (same)
...the rear of the truck rides a bit lower (~1") than I would like
...&/so, I was thinkin' a 1" "lift" should/would help "level 'er out", when loaded :thumbsup:
This works well for locating center:
The problem might be keeping the bit from wandering as you drill through 3 inches.
But your ingenuity amazes me...
So, with the bracket/holder thingy It's going to be 1.25 to 1.50 inches tall? or sumpthin like that? 1" rollers and bottom plate is 1/4-3/8? plus a little clearance. It's getting bolted in the center?
Solid plan, I don't see why it won't work.
Just thinkin out loud....
Would a block of Teflon or Delrin work just as well?
I woulda slapped some grease on that chunk of oak and driven off into the sunset.
Probably, although those would be a bit hard.
It seems to me the issue is the OE bumpers are missing, pretty typical for them to rot away over time. The cushion the ends if the overload leaf sets when there's no load from thumping metal on metal when you hit a pothole, but act as a shim when there is enough load to engage the the overload leaves
