Leveling go kart/axles problem
Kenpilot
Building my first kart and I just put the rear axle on and the rear tires (front were already on) and I noticed the rear end sits about 1.5-2 inches lower then the front. Unfortunately the problem lies in where I welded on the rear bearing hangers.These are the ones I have so I am very limited as to how and where I weld them to my frame because obviously I can't lower the hangers because then the hole for the axle is sitting in the middle of the square tubing.
http://www.amazon.com/Azusa-Go-Kart-Bearing-3-Hole-Flangettes/dp/B0000AX60X
I'm thinking of getting some pillow box hangers and attaching them underneath my square tubing frame but I think that will raise the rear end higher then the front. any problems with this? or should the kart be pretty level? Or I just saw a picture of somebody that welded a seperate attachement plate on the outside of the square tubing frame, right in the middle or towards the bottom of the square tubing, which allows the axle to sit a little lower then if he had mounted them on top of the square tubing but not as low if he mounted them underneath.
http://www.google.com/imgres?q=go+k...bnh=158&tbnw=225&ndsp=15&ved=1t:429,r:0,s:176
Any suggestions would be greatly appreciated.
Kenpilot
I guess I should add that ive already cut off the bearing hangers i had so I'm going to need to get new hangers regardless. Just not sure which ones I should get that will help
klicky96
Sandusky, Ohio
If you just want the rear to sit a little higher then just get some pillow blocks, weld you up a bracket that will fit your needs and put it together.
Kenpilot
Well i wasn't really looking to have the rear raised, just figured if i was stuck with one end being slightly higher then the other, it would probably be better to have the rear higher, would it not?
The rear is where the motor is right? Ya have the rear higher. It isnt going to matter all that much for this, on a compitition race Kart that might be a different matter. a couple of inches should be a problem.
With that said, make sure you now have enough chain to accommodate the new length.
Kenpilot
Correct, engine is at the rear. Its not a competition kart, just a project and something to run around dirt roads and in the woods with. Thanks for the advice!
A pillow block will sit around the same height as your other hangers so you'll probably have to make up a bracket regardless.
It won't matter if your front sits a bit low, in one or two ways it actually helps a little, front sitting high could have disasterous results.
Some pics would be helpful
klicky96
Sandusky, Ohio
True, Very true. I would never run a kart with a higher front end.
