Building my first kart and I just put the rear axle on and the rear tires (front were already on) and I noticed the rear end sits about 1.5-2 inches lower then the front. Unfortunately the problem lies in where I welded on the rear bearing hangers.These are the ones I have so I am very limited as to how and where I weld them to my frame because obviously I can't lower the hangers because then the hole for the axle is sitting in the middle of the square tubing.
http://www.amazon.com/Azusa-Go-Kart-Bearing-3-Hole-Flangettes/dp/B0000AX60X
I'm thinking of getting some pillow box hangers and attaching them underneath my square tubing frame but I think that will raise the rear end higher then the front. any problems with this? or should the kart be pretty level? Or I just saw a picture of somebody that welded a seperate attachement plate on the outside of the square tubing frame, right in the middle or towards the bottom of the square tubing, which allows the axle to sit a little lower then if he had mounted them on top of the square tubing but not as low if he mounted them underneath.
http://www.google.com/imgres?q=go+k...bnh=158&tbnw=225&ndsp=15&ved=1t:429,r:0,s:176
Any suggestions would be greatly appreciated.
