lawnmower VS. motorcycle engine
Rustydog2010
NZ Nutta :|
New Zealand
Whats CB750 going in? That buggy in your first post in this thread? If so some serious work would be needed before I even considered getting in that thing. Is that some sort of Chinese thing?
Jeremy.
fowler
Bullsbrook West Aus
withb that 750 in it
u will need new suspension all round
better brakes
better tyres
better roll cage
and proberly better chassis
id personally start from scratch
id have stopped at 350 with that frame
not rying to be negative but u have brought yourself alot of work
well in my eyes building is as much fun as driving (most of the time)
rabies
punching kittens
iowa
il make it happen. and il make a build thread.,
this wont be made to go fast. but to climb hills and mudding.
basicaly it will be a sandrail that will get expanded more and more as we go along
ive done some hybrid swap stuff before but no motor/bike/go kart stuff.
the kart is a carter trail hunter. US made.
the plan is to use the hydro brakes off the bike.
use the cluster
get taller stiffer shocks all around.
i have bought bigger tires.
also looking for thicker tie rods with some bushings(cushion)
the rear axle will get off from an ATV. live axle.
which will all come together with some fab work.
and new seats. clutch pedal, shifter. and then weld a few bars to hold the motor.
and go from there. prolly end up welding alot more stuff.
its going to be fun indeed. :)
now...what section do i put a build thread?
