il make it happen. and il make a build thread.,
this wont be made to go fast. but to climb hills and mudding.
basicaly it will be a sandrail that will get expanded more and more as we go along
ive done some hybrid swap stuff before but no motor/bike/go kart stuff.
the kart is a carter trail hunter. US made.
the plan is to use the hydro brakes off the bike.
use the cluster
get taller stiffer shocks all around.
i have bought bigger tires.
also looking for thicker tie rods with some bushings(cushion)
the rear axle will get off from an ATV. live axle.
which will all come together with some fab work.
and new seats. clutch pedal, shifter. and then weld a few bars to hold the motor.
and go from there. prolly end up welding alot more stuff.
its going to be fun indeed.
now...what section do i put a build thread?
