ryf
- Messages
- 309
- Reaction score
- 2
I'm working on the governor issue, most likely removing it though. the axles are 2 to 1 for now (there is a 25 tooth trans side, 11 tooth axle side) and I can play with pulleys without altering the governor. I have alot of options.
it is 2 chains, if I had been able to find one, a 700 series tranny is single output, but it has a chain reverse, which is not good if you are planning to rev it up alot.
in other news... I've sorted my brakes! I'm planning on using an 80's prelude front disc and caliper for brakes.. found a good deal on the caliper with pads and bracket, NIB. using a escort master cylinder to pump it. should be wicked.
