Lawn Boy vert to horizontal mods
Walter Keller
tampa bay area
Anyone here mod a vertical shaft Lawn Boy engine for use as a horizontal shaft ? I've seen the couple examples on Youtube from a few years back - looking at doing the needed mods for a minibike build I'm working on.
Its difficult to do. The easier way to do it is to get a horizontal shaft engine. If you want to keep this engine, you'll need a right angle gearbox.
Dingocat
Broke
NE Ohio
Alot of the lawnboys are two strokes. Shouldn't it make it easier? Even though impractical. I agree. It's great to use what you got lying around but at a certain point it isn't worth it.
a two stroke is rather easy to convert;
you need to rotate the carb and fab a mount and that's essentially it already.
rushking19
Richmond Virginia
Yes a guy named russ and a few other people have you eill.need a custom engine plate made up and you will need to get the shaft on the crankshaft cut down to fit a normal clutch
JTSpeedDemon
2019 Build Off Winner!
Texas
If it's long enough. All the mowers I've seen seem to have short PTOs, but IDK.
I once wanted to convert a 149cc Lawn Boy 4 stroke we had to a go kart, but then I realized it would be a lot of trouble. So OP, is it a 2 or 4 stroke?
rushking19
Richmond Virginia
Yeah if it's the 2 stroke go ahead, mostly if it's a duraforce motor
rushking19
Richmond Virginia
Here's one of my favorite duraforce builds it's not only converting it from vertical to horizontal it's also modding it for more power too different carb a Tillotson head gasket mod too reed valve mods to make it have even more hp then 6.5 russ helped with this build and they estimate around 9 to 10 hp with all the mods
http://www.diygokarts.com/vb/showthread.php?t=1541
---------- Post added at 07:32 AM ---------- Previous post was at 07:31 AM ----------
http://www.diygokarts.com/vb/showthread.php?t=1682
---------- Post added at 07:32 AM ---------- Previous post was at 07:32 AM ----------
http://www.diygokarts.com/vb/showthread.php?t=1732
---------- Post added at 07:33 AM ---------- Previous post was at 07:32 AM ----------
http://www.diygokarts.com/vb/showthread.php?t=2399
Video of it running
https://youtu.be/1ETJey1MQGQ
