kt100 carb adjustng
spools
Hello I just bought my first kt100 yesterday and before i ruin it I would like to know about the carb settings,Ive read that most people run about 2-1/2 out on the low needle which I assume s the large T needle closest to the motor correct?and about 1/4 out on the low side which is the needle next the the large T,So my question is when they use the term "out" does this mean turn the needle righty tighty all the way and then unscrew the needle 2-1/2 turns lefty loosy from fully tight or is this backwards on the adjustments?
fowler
Bullsbrook West Aus
all engines are slightly differant
it will take some fiddling to get it perfect
what u have is a round about setting
yes id say thleet is right
if it runs then id leave it alone
if its off a little id adjust it as it runs turning it 1/16 of a turn at a time
anderkart
Surprise Arizona USA
Yes that carb adjustment info you found is starting from them screwed all the way in. Just lightly seat them in untill they stop, if your screw them in tightly you might damage the carb.
the-cyborg
Spring, Texas
Assuming you're kt100 still has the stock Walbro carb on it, read and follow this article to the letter.
http://nkn.com/nationalkartnews/articles/AnatomyOfWalbro0708.pdf
Stock Yamaha settings say
  • Set your popoff 10-12 Lbs
  • Low needle - 7/8 turn
  • High needle - 3/4 turn
That being said there are no magic one setting fits all, this is especially true with 2 stroke engines.
There are many things factor in on correct settings.
  1. Track conditions
  2. what type pipes you're running
  3. what type clutch you're running
  4. Altitude
  5. Humidity
  6. Barometric pressure
  7. Temperature
  8. Fuel/oil ratio
Too rich and it'll bog and run like crap and you'll foul plugs.
Too lean and you'll stick a piston or worse.
You're looking for the fine sweet spot in between.
If anything you'll want it just very slightly rich, when you get Run flat out, wide open throttle, and try to get the motor to peak out at maximum RPM. It will probably sputter at the high end, so turn the H screw in 1/8 of a turn. Try it again. Soon you will find the spot where it screams like a mad chainsaw and sounds like it’s going to fly apart. You don't want it there. Two strokes need excess fuel for internal cooling and they need the oil in the fuel for lubrication. When it's screaming like mad, it's on the ragged edge of being too lean, so open the H screw just a little so it burbles a little instead of screaming. Better safe than sorry.
One thing to remember on these carbs...The H circuit is additive to the L circuit...if you opened (fattened, richened) the L, then you have also richened the high speed operation...so always set your L first, then the H.
NEVER >>> NEVER >>> NEVER go tighter than 3/4 of a turn from seated on the H needle unless you really, really want a brand new engine. If you need to go tighter than 3/4, something's wrong and you need to get it fixed. Gasket leaks are the usual suspects here.
