killdozer help
josha907
aitkin MN
Hello I did a killdozer style of go kart build. Just wondering if anyone else has and how they extended there throttle cable.
josha907
aitkin MN
Here is a few have to make it out side to take some better ones of the throttle setup I have now. Let me know what you think?
justinlogue5_0
Can't leave it Stock!
Tn
I am not sure of what a "killdozer" is but as far as the throttle cable being longer, I guess it has the factory style cable and I agree they are only so long so could you use two cables? One from your peddle down to a spring loaded block, them the original from the block to the carb? Sort of like a lot of carts that has a solid rod going under the seat of the cart which then connects to the flexible cable running up the carb.
Any ways, cool build, I bet that thing will be a blast! :thumbsup:
josha907
aitkin MN
I had it running it is a blast. But I hit a tree and bent my axle.I have the machine shop milling me one because I couldn't find an inch and a quarter with the step down
This is killdozers thread
http://www.diygokarts.com/vb/showthread.php?t=9565
He took a snowmobile engine and stuck it on a kart. He cut the whole engine and bracket out of the snowmobile and welded it onto a kart
josha907
aitkin MN
here's some pictures of the throttle set up now. the only problem with it as I bent it when I rolled it .so I'm just wondering if anybody has a different idea so it ain't sticking out the side
qtband
St. Louis, MO
The 2 cables come from the carbs and go to a plastic block. Take that block apart and replace the short single cable with a brake cable or throttle cable of the size you need. You may have to file the end "ball" of the cable to fit your block.
qtband
St. Louis, MO
I'm talking about the "block" in the yellow circle.
