Kids Kart Width?
Pinhead
Kansas
I've got an old lawnmower frame and am considering "converting" it to a go kart for my kids (oldest is 4 currently).
I don't want it to go much over 10 mph and was thinking of using a weed-eater engine for power.
My question is, how wide should it be to prevent tipping? It's pretty tough to flip by hand as-is and I'll be keeping the seat and engine as close/low to the frame as possible which should help.
Mock-up pic for attention.
Don’t use the crazy car either. Build a dedicated kart. Weed eater engine might not have enough power to move it. Try the 79cc Predator and gear low for slow!
Pinhead
Kansas
I plan on using the little car basically as a seat with a dedicated/built frame beneath it.
I found highly-rated 49cc 2-stroke with built-in clutch and 3:1 gear reduction. Seems like it should have plenty of power for my needs (and half the price of the Predator).
https://www.amazon.com/dp/B07WXHZKLF/ref=cm_sw_em_r_mt_dp_52SEYAHCGNPQ7PTMT0ZK?_encoding=UTF8&psc=1
Try it, it may work. But build it light. I still would not use the crazy car though. Not enough support in the seat in the event of a crash.
pRoFiT
Can't buy it?, build it!
California
sounds like you are already mind set on getting 2 stroke. but for kids? going to be loud. i made a scooter trike one with leaf blower motor. was soooooo loud. i would not expect the kids to like that. maybe fire up the weed eater next to the 4 year old and test the reaction first. my guess is they are not going to like it at all. Be ready to run after them. Might be good to just go electric. 10mph isn't that hard to do and super quiet.IMAG4871.jpg
That being said scooter trike was super fun to ride if i could keep the motor engaged. would like to redo with clutch some day. This is direct motor shaft to wheel drive ;) used the old power your bike trick.
Pinhead
Kansas
sounds like you are already mind set on getting 2 stroke. but for kids? going to be loud. i made a scooter trike one with leaf blower motor. was soooooo loud. i would not expect the kids to like that. maybe fire up the weed eater next to the 4 year old and test the reaction first. my guess is they are not going to like it at all. Be ready to run after them. Might be good to just go electric. 10mph isn't that hard to do and super quiet.View attachment 130783
Not necessarily. But I ain't rich and 2-strokes are cheap.
pRoFiT
California
HF Predator can be had for $100. or find a used lawn edger motor.
But yah motors aren't cheap. but it is the powerhouse of the go kart so it should be the most expensive part.
Just pick up some ear protection for the kids.
To your original question. This is just my opinion. If it is a 2 seater not over 4’ wide to the outside of the tires. If it is a 1 seater not over 3’ wide to the outside of the tires.
For kids to operate, and learn how as they go, I can imagine them learning to fill the gas tank when Daddy isn't handy to do it. At that point I'd get very concerned about the need for 50:1 premix 2-cycle oil in the gas, as opposed to the simplicity of a 4-cycle engine not needing anything in the fuel tank but gas.
Pinhead
Kansas
These ain't city kids. My 2-year old boy already knows the weed-eater and chainsaw needs 2-stroke oil. ;) They're not going to be messing with gas for a long time, anyway (years, more than likely).
Willie1
Newport, Mi
Consider using a longer, like 36" fully keyed axle to start with, and retain the wheels/hubs with lock collars. This wide of a track width will give the kart stability to start with. As their ability improves you can cut the axle down, and slide the wheels/hubs in to a "sportier" track width.
