Keyway issues
Robmus18
Pennsylvania
I recently bought a predator 212cc engine from harbor freight, and when trying to install the clutch (which has a built in key) the key that came with the engine wouldn't come out of the keyway. I tapped it with a rubber hammer, tried to pry it with a screwdriver, pull it with a clamp tightly on it and it won't come out. Any idea of how to get it out?
dengieboy
Essex England
stuck key
ah my thoughts would be a little heat from a gas torch on the end of the crankshaft some freeze spray on key key then a little tap with a sharp small chisel
Axx3d
MN
I just bought a 212 and the key was stubborn. I used a punch and a hammer and it drove out.
