Kawasaki Sled?
crazycart
RedNek Engineering
MINNESOTA
Kawasaki LTD's were the fastest in their day. Quad plug motor. They are good sleds but parts are hard to find. Plan on replacing more than a rod. Crank seals, maybe bearings, piston(s) etc. It doesn't end at the engine. It will take some major $$ to get back to life...But if your up for the challenge and have the knowledge by all means do it.
Kaptain Krunch
Pro Junk Collector
vermont
Like crazycart said, it would be a really nice sled...but it needs pipe, cdi, carbs, and probably more than the rod. Plus you should expect to be replacing atleast a few bogey wheel bearings, and most likely the driveshaft bearings.
Unless your into the vintage stuff, it would probably be cheaper in the long run to find a good used mid 90's sled.
mrfreyguy
Buggy Almost Done
Iowa
I was thinking that if it was realy bad I would buy a F/C 440 to replace it. I really don't need a moneypit, I would rather just replace the motor.
jr dragster T
Cold place
Pretty well any older sled you get is going to need alot more work then first thought. I was told my sled simply needed a new base gasket! Look where it is now lol. Ended up being a entire engine tear down/clean up new piston rings etc.
mrfreyguy
Buggy Almost Done
Iowa
The guys being a a$$hole. I asked if I could buy just the chassis and he just stopes responding. So I guess that's over. Back to building the kart...
crazycart
RedNek Engineering
MINNESOTA
LTD's are rare sleds. You don't want to ruin one with a F/C engine anyway. MAJOR downgrade from the 4 plug 440. It would just be wrong....
mrfreyguy
Buggy Almost Done
Iowa
I get what you mean. It would kind of be lime putting a Honda 6 in a mustang lol I wonder how much fabbing that would take
