Kart Rods
I like it,
I guess it would be cool if you bend the side bars down to be almost horizontal somewhere about 2-3rds their height
then add a set of short podless nerf bars so that he ends up with enough wings to rule the sky over germany ;)
*came a roar and a thunder man had never heard
like the screaming sound of the big war bird*
dammit earwigs in brain...
Kelly Wood
The Mad Kartist
Salt Lake City Utard
I like it,
Thanks!
It will have some version of the tri-wing somewhere, I've got ideas but they'll come out as I continue on. I rarely plan a lot of this. I just get a vision and go with it.
Kelly Wood
The Mad Kartist
Update:
Ah, the usual day. Get up, work for 9 hrs or so, come home, go to the store, stop at the hardware store, do this, do that, eat...
Outside buddy. We gots work to do.
Step one.
Rename it. My karts are girls. Why? Because they're a pain in the behind somedays.
So, bring on the Baroness.
Step 2.
Out with the frame, setup a little work space including 2 cutoff wheels, safety glasses, a cooler, and some spray paint.
Step 3.
Cut it into usable pieces. Note, I don't grind down the sharp edges, ever. Bend the steering rod up to a new position.
Step 4.
Bring back the steering hoop and slide it over the steering shaft, now cut in half. Position it forward & down a bit, reinsert the cut steering wheel and tack weld in place where it will now be.
Step 5.
Cut off the rest of the steering wheel. Don't ask why, it's just how I work and it's how I roll pal.
Step 6.
Take off the extra hardware, grind off / or sand surface rust. Wasn't much so not much to do here.
Step 7.
Ah, the wheels I'd envisioned for the front.
Step 8.
Clean frame a bit, paint. Assemble wheels on axles & steering rods. (yes, I'm painting it now, it's just spray paint. Helps with the creative process. When the frame is right, I strip it then repaint... with spray paint.
Step 9. Allow to dry for days.
Yup, put it back together when tacky. That's how you get the hot rod look. Paint it, then work on it, gives it that certain look.]
Why the half-ashed approach? Because. I'm gonna use the thing & beat the crap out of it. The welding isn't pretty, nuts & bolts don't match, the paint gets chipped & dirty.... and it looks like it's been in a battle, with some style thrown in.
If I took the time to actually make the super pretty welds and the powder coating, etc... It'd defeat the purpose entirely. Perhaps one might even start rubbing it with a diaper & making love to it. Nope. Make it with what ya got, use it, break it, fix it, update it, drive more.
It's a kart rod.
More soon,
Kelly
Kelly Wood
The Mad Kartist
A few other pics.... plus, does anyone need these Manco pedals? Comes complete with all hardware, springs & bolts. I won't need them.
Kelly (destroyer of karts)
XtremeAaron
Nice, I like the vision your having with this.
What do you want for the pedals?
Sent from my Razr Maxx.
Wow, this is going to be epic.
Do you happen to have nine [NEIN! :D] empty tincans handy?
Why?
you could add this to the front:
(that's an image of THE ONE Fokker Dr.1 engine )
PS
awww great.... now it's The Meteors...
Kelly Wood
The Mad Kartist
Excellent idea. I've been struggling with the front piece a bit but it will incorporate some version of that... dunno how yet, I'll just let the creativity flow & I"m sure it'll come out ok.
With Sarge's front end, I hit artistic block (writers block for artists) for months... and in the end, a simple gas can did the trick. Might have to bring out the solder, brazing torch & for this front end. Maybe throw in a touch of steam-punk, in silver.
Wait until you see the machine gun.
We'll see.
For those watching, please feel free to throw your ideas in. If I use your idea, I'll reward you. Yup.
Kelly Wood
The Mad Kartist
Those black wheels? They're just spare stuff I've collected over the years. Typically, the wheels I use are used. I rarely buy anything new. These wheels are commonly found on 70's & 80's minibikes or go karts. So, cruise your local ads & find some junker minibikes or karts and get to it!
Kelly
a hole in the center of the iron cross, I'd say;
split the fin in half an connect the halves with hinges
Add a small bar on the bottom of the back half,
two more cables and you're all set for aerodynamic steering assistance :D
'sid (jk)
Kelly Wood
The Mad Kartist
You rule. Problem solved. ROFL! Check the Wankel kart thread and you'll see that I'm going to put a small Wankel Rotary beast on this one, screw the 4 strokes.
Just read that..
I'm jealous!
If you think you could buy a german engine (SACHS) like that in germany you are wrong, wronger the wrongest... :censored:
They simply do not exist (or not anymore maybe)
Get it Kelly... pleaaaaase :D
Kelly Wood
The Mad Kartist
I don't know about that particular one on ebay... I live in Utah, greatest snow on earth and there's a MILLION old snowmobiles around here. I'll find one here. not my style to buy new or NOS stuff. But, a wankel is going on this, it matches the theme, weird.
