Made a battery tray , battery fit nice..... Tacked in in place, and can't put battery in unless I take body off.... No can do at the moment.... Battery install can wait.
Got my new 9 tooth sprocket in as well as some new chain. I did not order enough chain..... Here we go again... Ordered more chain. Should be here by Friday.
Jackshaft looking pretty good. Just need to weld it in now , as it's just tacked in place too ....
Gonna eat dinner or a snack , then start on the welding in the shifter ....
It's finally coming together...... New cables will be here soon. Ordered a wiring kit with the same plugs as in these engines, so I can make my own harness with better wire. It will last longer as these Chinese harnesses only last a year or so , depending on how much you ride...
I have the rods I need for the shifter linkage. I need to machine 2 pivot cups out of Mylar to use as bushings for the crossbar ends. The crossbar is the bar with the two tabs welded to it , about 30° apart, or 60° off the first tabs centerline.....
Well, hopefully will post more pics tonight of the shifter in place. Kinda bummed out about the chain being short.....
I used to have 10 feet of nickel plated chain that would have been perfect for this, but I have it to my son....
Till later ......
