What makes me wonder though is
it
defaults to
inches kg and km/h
and while that's inconsistent it's the most convenient even for real metricians
Hang on,
close the Safari Browser,
check in "Settings -> Safari" and make sure "Block all cookies" is turned off
then scroll down click on "Advanced" then I think it's "Website Data"
click on edit and remove websitedata for kartcalc.net
(that unfortunately deletes the local database as well.. so all stored karts will be gone **)
it also deletes all cookies, which is what we're after atm.
Now, reopen safari and kartcalc.net should set new cookies (default ones)
and before you alter the settings, check that wheel diameter is now in inches.
if it is.. change to lbs and mph if you like
check again and report back.
Once your settings are as you want them to be (and working) you can block all cookies again if you want to.
(my web-app doesn't mind much)
In case you want the kart to be backed up on my global database,
open the kart in your db, tap on the "Tacho" button in the footer and back out again,
confirm storage of performance data.
the "tacho" button should now read "share" and will push the information to my website's database.
Unfortunately, the app has no way to reread that information back into your device's database,
but at least you have the information readable.
Proper speedrun is unlikely going to work these days (https and such),
but if you see hands on the dials...
you're lucky and can indeed get a reading
