karl
Figured Id show off what I have been up to.
After I ran the 20hp briggs twin for awhile, the frame was bent and sagging. For The third time I cut the kart in half and rebuilt.
I did away with the torque converter and running a predator again.
It has a gx160 head with thin steel gasket and a marine grind cam.
Predator block, crank , rod, piston and carb.
I am using gx160 aluminum push rods, with 196cc clone studs and rockers, with 20lbs springs. With 93 octane and some booster it runs strong, pulls very hard and fades out around 5k.
With a 6 to 1 gear ratio it spins off the line and has tons of wheel spinning torque , scary fast in a smaller track. I put 13in x 5 tires on 6in wide rims with tubes.
Drift machine , rocket around the yard
I was too cheap to get a top plate so I hacked it.
I had a kx250 rear master cylinder and caliper, Ordered $7 brake pads and a $20 disk for the 1in axle. I used a modified Hurst shifter for a muncie 4 speed to make a drift stick.
Not bad for $28 I think.
Anyway it is the best version of the kart so far and I cant wait to get the e-brake working!
I finally will have something with brakes!
Enjoy!
Enjoy!
