just picked up a 110cc quad ,and i have a few questions
zip kart
ireland
i just bought a 110cc semi-auto quad ,3 gears and reverse shaft driven ,its only 3 months old and its in good nick ,just want 2 no how fast would u think it would go ,didnt get a chance 2 bring it for a good spin ,and how do i adjust the power of it ,i was told i can adjust it to suit age any help would be great?
zip kart
ireland
its a 110cc loncin quad semi-auto 3 gears and reverse
im about 65kg
its a shaft driven quad so theres no chain so how can i find out how fast it will roughly go?
SpeedBoy
Redneck
Hmm im not sure but I will bet someone here knows. Can you just get it up to speed on a road and have a car pace you?
im about 65kg
zip kart
ireland
i didnt get a chance to do that yet dats why i was wondering
and how can i adjust the speed that the quad goes aswell
DaiSan76
Nixa, MO
im about 65kg
I have never seen one of these shaft driven, but in any case you are probably looking at similar performance to this. 35mph max.
zip kart
ireland
ye its shaft driven i was told thats better because i wouldnt have to worry about chains snaping and that
With maintenance, chains shouldn't be snapping. They do wear out eventually though. The liability I see to shaft drive, is that it seriously complicates regearing. Changing the final ratio in a chain-drive system is easy. With a gear drive (shaft), you have to HOPE somebody makes a gearset that meets your needs, and you'd better bring your wallet...
zip kart
ireland
also my quad has no air filter its just a plastic pipe coming from d carb into d front light ,sud i have a air filter?
zip kart
ireland
also ders a baffle in the exhaust with 2 screws in it ,i unscrew them ,it moves but it wont come out because theres a weld around the tip , if i did take it out would it make any difference in power ,i know it will be louder anyway ,and would be safe to do that
SpeedBoy
Redneck
There should be one... you never want to get dirt in the carb because it would get into the engine and could cause issues....
zip kart
ireland
so id be better off leaving the muffer in ,i thought it would make a difference in performance if i did ,and il get a air filter aswell
zip kart
ireland
how often should i change the oil in the drive shaft
because today i checked it and the oil is like grease its not really oil ,is that the way it should be ?
sometimes its hard to get into gear ,its semi-auto by d way ,does that mean i should change it?
SpeedBoy
Redneck
If it a 4 stroke and not a 2 stroke taking the out as far as i know will give you better proformance because of no back pressure, but with 2 stroke you need back pressure for more proformance. For the oil i would say once a year and if it gets greasy like that i would think it would be ok aslong as it is thin enough to drain out yet. You could look on the fram for a model number or a exact type and google search a mannal fo it.
zip kart
ireland
so if i take out the baffle it will make a difference in power but what im afraid of ,will it damage my engine ?
zip kart
ireland
also the air filter thats on it is just a plastic pipe coming from the carb and it goes into the front of the quad fairing and theres a sheet filter in there ,should i just buy a normal K&N Air filter ?
