Kaptain Krunch
Pro Junk Collector
A crack in the cylinder wall could cause you to burn oil, foul plugs, etc...
Yes you are more likely to find a crack in a new clone, but like i said. Replacement warranty.
Overheating any engine is NOT hard, its as simple as not filling it with oil. Which is probably one of the most commonly faults with maintaining an engine. And this destroys the whole engine, to were its not worth rebuilding.
If the crack is big enough to cause you to burn much oil, you would notice it during disassembly.
If someone is dumb enough to run an engine without any oil...
Running it without oil will indeed cause it to build up a lot of heat, rapidly wear every moving part, and seize up. Rebuilding an engine like that would require at least rings, maybe rod, thats about $40 maybe $50. Half the time with these engines you can just get a breaker bar on the flywheel nut, free up the engine and run it till it loses too much compression. But of course if you find an engine that doesn't turn over at all, you should know what your getting into.
you will be more likely to find a defect in a new clone for sure, maybe one time it will just be the block or something, but what happens when theres a defect in the flywheel or rod, and parts go flying?
