Just bought 3 dingos
Eric87
So I got 3 manco dingos over the weekend . One has a 10 hp Tecumseh with electric start. One has a 9 hp Briggs with electric start. The last one has a 5 hp Briggs . All need some sort of work done to them . Anyone know where I can buy a manco style jackshaft plate?? Or should I just use what BMI sells. Using 5/8 jackshaft . BMI sells 3/4 bearings . Dingo 1 picture.
Dingo 2
Dingo 3
Joe-405
Enjoying New Projects
U.S.A.
Location and I'm on my way ! But seriously been wanting another one. Just can't find any clunckers in my state. Been looking tho.
Poboy kartman
Senior Moments Member
White Settlement Texas
He's probably in Australia...I hear dingos just wander in around there...But...don't hold your breath...I've found if people haven't bothered to fill out a profile location when they've been around that long they usually don't....
Eric87
Ok dingo 1 is up and running .just needed a throttle cable and a new belt . Also had to remove a motor plate that was stacked between the motor and jackshaft plate . Repositioned the motor on jackshaft plate and drilled new holes . This dingo has a Tecumseh 10 hp but came with a comet 30 series kinda strange . Does anyone know the purpose of the plastic fan that bolts to the end of the driven. The pic is off of another kart I found on Craigslist.
That's a cooling fan. Keeps air circulating but works best in conjunction with the TAV shroud. Kinda handy little doo-dad as heat is the enemy.
They have centrifugal clutch fans too--I've only seen them in parts diagrams though and mainly or only on Mancos.
Im guessing there was a cover like a snow machine... to keep the clutches cool, otherwise contained within the cover and no air movement....
Haha... double post at the same time...
Eric87
That's what I thought . I wonder how long that belt is gonna last on that TC with it being a 30 series. Or is that what came on it new.
Eric87
Just got back from shop did all the welding on dingo 3 . Floor pan , roll bar ,and seat mount . Picked up a new predator 212 for it and ordered a new tav2. Still missing the back roll bar . The one I have was cut and the bottoms are missing. Gonna have to make something. Don't have a pipe bender.
---------- Post added at 03:40 PM ---------- Previous post was at 03:35 PM ----------
I also did a mechanical disc brake conversion on dingo 3 . Gonna make my own brake rod out of 1/4 " round steel .
...I also did a mechanical disc brake conversion on dingo 3 . Gonna make my own brake rod out of 1/4 " round steel .
That is not a bad idea--making your own brake rod, especially since complete Manco rods are probably gone from the parts suppliers by now. I've got one that's rusted pretty badly--just never thought of making my own. THANKS.
I know some kart makers use braided cable for brakes but there's no beating the feel of a solid rod...
Eric87
I have a good brake rod just don't want to cut it. The home made ones work great as long as it is a straight shot .
