just a few questions about batteries
britishninja
Scotia Glenville , NY
ML-TOYS
long island, new york
How many amps is your motor.
The lower the ah rating on the battery the shorter the runtine. Those are 8ah so you will get very very little time out of them.
jman231994
Australia
You means watts. He probably doesnt know the amp draw. Might do though haha.
You also want to look at battery weight. You cant just say smaller is less runtime. Logically it should be but in reality it isnt, if you have a heap of weight on board from massive batteries then your motor will end up drawing more current when accelerating and may not give what you expected. In saying that, 8aH is pretty small, if your motor is 1000w you should expect less than half an hour run time. Probably more like 20mins and not at full power the whole time
