Bando
Wow, nice buld man
I just have a little suggestion concerning your alternator:
I'm cant tell what model alternator you've got there, but many like yours have an extra high 100 amp max output level.
Something a lot of guys dont realise is some high output alternators can take up to 5hp of the engines power to spin when the battery is low/in need of recharging and the alternator is charging at its max output level.
Besides using a larger diameter pulley, a little trick some drag racers do is wire a toggle switch up to the alternator plugs ignition feed so you can turn the switch off to temporarily disable the alternators output for an extra burst of engine power whenever needed.
I was just thinking that would be a cool mod to do on your cool jeep kart there...
Hi. The alternator came from chevy sprint 3 cyl. Not a heavy alternator is about 65 amp. I put it to use headlights, brake light, taillights etc.. Only necessary lights. No heavy loads. I did not do any calculations for sprockets and alternator pulley but I can change it at the end, when I can see what happens. I can make changes later if something is wrong.
