JB weld
personally I wouldn't rely on PVC for a RC Kart...
Yes I know last years PVC Kart and I remember that it was cheated a bit ..
still awesome... but to add rigidity he cheated a bit ;)
So I'd use steel tubeing for a project like this..
and if you don't want to or are unable to weld the tubes..
use connectors... there are nice railing connectors ou there.. they should take 1" tubing and with a few setscrews (and through bolts) they should provide enough strength for an unmanned vehicle of your desired size.
something like this
Also: it'll look cooler than PVC :D
No honestly.. as soon as you find someone willing and able to weld it up, you can remove the connectors and weld everything up just as it should be :D
fowler
Bullsbrook West Aus
Pvc does flex
Over 8 foot its really bendy
Ever got a 1 foot section and tried to bend it
Its pretty ridgid
And u don't want a totally ridgid frame anyhow
davidbooth1991
Nottingham UK
You need to get the thinest walling 1 inch tube you can and use these 'key clamp' brackets. There designed for express handrails but you only need an Allen key (6mm).
davidbooth1991
Nottingham UK
F.h brundle sell them and steel stockists do them b&m steel or fabricator workshops might let you have some. Just Google one inch key clamp for handrail.
ML-TOYS
long island, new york
Just for fun i may even build a pvc r/c about 3 feet long with a weedwacker motor just to see how it works. 3/4 pvc pipe elbows tees and misc fittings and good to go.
firemanjim
Just kartin' around....
Houston Texas
Hmmmm, I always wanted a boat..... I could do an r/c pontoon boat with a weed eater shaft down into the water..... :lolgoku:
Poboy kartman
Senior Moments Member
White Settlement Texas
Or.....Duct tape. .... (now I'm just being silly and mean...).....but it always worked for Red Green. ......
"If the women can't find you handsome. ...at least they should find you handy".....
And hey...." We're pulling for ya. ...we're all in this together! "....:thumbsup::lolgoku:
fowler
Bullsbrook West Aus
Thinking the servks are going to be the most expensuve parts
I might have to give this a shot
Do some reasearch on prices when I get home
Got a spare 35cc wipper snipper motor and a whole pile of pvc pope abd fittings left over from my retic fit
I obviously can weld and have a welder so it wont be a true complete pvc chassis
youngengineer
Cumbria, UK
Hi, did u get one built??
