Jackshaft question
onemrbigg14
im a big guy 300 pounds I was wondering what should I use a jackshaft a torque converter or a clu
tch im really lost guys thanks
onemrbigg14
the go kart is 6 foot long after i extended it my engine shaft is a 3/4 shaft with a one inch axle i have a brake drum sprocket that the brake drum goes into tire size is 11 inches tall by 4 inches wide on a 5 inch rim im using a differential axle the gokart is a 6.5 honda horsepower motor with govener off about to upgrade the valve system thank you for all the replies
onemrbigg14
72 tooth rear sprocket and what should i upgrade for my internals i was thinking aluminum flywheel but do i need a bigger cam and the terrain is a all dirt track road course not to bumpy and thank you for that post for me to read does anybody have any opinons on which brand or exactly what i should else do thanks
My first thought is that you need to find your period key. I shouldn't have to struggle to figure out what you're after.
Second- billet aluminum connecting rod.
Third- a decent clutch oughta work out for you.
onemrbigg14
thanks. and im very sorry about that. and what type of clutch should i get the most expensive one, or will a cheap clutch work
A picture tells a thousand words :thumbsup:
onemrbigg14
ill post pictures tonight guys been doing it on my phone i got a computer now thanks for all the replies and patience
