onemrbigg14
- Messages
- 9
- Reaction score
- 0
im a big guy 300 pounds I was wondering what should I use a jackshaft a torque converter or a clu
tch im really lost guys thanks
...a 6.5 honda horsepower motor with govener off about to upgrade the valve system thank you for all the replies
72 tooth rear sprocket and what should i upgrade for my internals i was thinking aluminum flywheel but do i need a bigger cam and the terrain is a all dirt track road course not to bumpy and thank you for that post for me to read does anybody have any opinons on which brand or exactly what i should else do thanks
the go kart is 6 foot long after i extended it my engine shaft is a 3/4 shaft with a one inch axle i have a brake drum sprocket that the brake drum goes into tire size is 11 inches tall by 4 inches wide on a 5 inch rim im using a differential axle the gokart is a 6.5 honda horsepower motor with govener off about to upgrade the valve system thank you for all the replies
