Brianator
Gettin' er done!
Curious what bolt length you used and whether you used a spacer?
I have a TAV2 with backplate and used a 3/4" shaft collar plus a 3/4" shim washer from Home Depot to get my belt correctly aligned but each application may be slightly different.
I believe the bolt I sized up was 2-1/4" and I may have filed it down a hair. You can use a zip tie, welding rod or something similar to probe the hole and get your measurement once you've got your alignment good, use the spacer washer and another small washer when probing the length and get a bolt that is just a hair shorter than your measurement to allow a little bolt "stretch" for torquing it down, you dont want the bolt to bottom out.
Dont forget to clean the crank threads well and use blue (semi permanent) threadlocker!
