Is this engine mounted sideways??
AZDesertRunner
There's a small offset between the front and rear pulleys. Is that ok? I have another small spacer, but with it on everything just barely fits on the drive shaft.
I got the engine mounted and running. Gonna let it idle for about an hour to break in before I go on a test ride.:eek:
Dingocat
Broke
NE Ohio
Too much. You want the flat faces to line up. Could try to get rid of space behind the driven pulley. May have to move your axle sprocket.
Budget GoKart
Aka a kenbar
roachdale, indiana
212cc or any traditional small engine will fit fine but i suggest a 420cc i have a subaru i bought for 50$ just waiting on the tc and im good to go!
---------- Post added at 10:29 PM ---------- Previous post was at 10:28 PM ----------
He may not be able to usually on yerfdogs they rust to the axel but who knows
AZDesertRunner
I took it for a spin and it goes. Much faster than it was with the Tecumseh.
Moving the engine to the left seems like a huge pain in the ***. So does moving the sprocket to the right. I'm going to try a spacer on the drive pulley first. If that doesn't work then I guess I'll be drilling some holes in the engine baseplate.
I'm just worried about the circled part only having about an inch of driveshaft in it. I saw a youtube video where the guy claims that this is a common issue and people say not to worry about it. Opinions on that?
KartFab
Dallas, TX
You can do what I did here. Notice where the sprocket and chain are now? This is the same go kart too by the way.
KartFab
Dallas, TX
no fab work. Just spacers put in different locations and had to remove the axle sprocket and flip it 180- degrees.
AZDesertRunner
Where do y'all shop for tires? BMI and GoPower only have 1 turf style option in 15x6-6. I want something with a more aggressive tread pattern for dirt.
Do you have a Tractor Supply or Northern Tool+Equipment near by? They usually have better selection of turf tires and tires in general.
