Is my motor really a stroker motor?
Stroker face
I'm needing some knowledge and I Know there is plenty to learn from you guys. Ok I have a 6.5hp predator hemi 212 factory and I have a 5hp honda gx 140 factory. I took the gx140 head and rods and put on the predator 212 just taking a wild guess and it runs great. Seems like a good bit more all around power. By doing this does it make it a so called stroker motor? And any clue about how much more power it gave it? And last question if I put the predator head and rods on the gx 140 Honda will it also have a increase in power and a stroker motor also?
Just starting to learn and experiment with small engines. All help with these questions will be truly appreciated.
Dingocat
Broke
NE Ohio
A stroker is when you increase the "stroke" of the engine, so you would need to change the distance the piston moves, aka a different crankshaft to increase the amount of travel. Any additional power you are seeing is because you have a smaller head on a larger engine.
Dingocat
Broke
NE Ohio
I'll leave it to someone else to explain better.
No, you got lucky the piston did not hit the head or the piston skirt did not hit the crankshaft. But otherwise I agree with Dingocat.
Good thing I wasn't there making that swap for you. I don't get massive infusions of blind luck like you did, if I'd done it every part of the rotating assembly would have slammed together and exploded that motor.
