Installing PTO bearing?
newrider3
Colorado
So I've been stalled for quite a while on my Briggs build-up due to the fact it has a pto side crank bearing. How do I go about installing the **** thing? It is press fit, but obviously I can't stick my engine in a press. Any suggestions?
Kaptain Krunch
Pro Junk Collector
vermont
Chill the bearing and heat the case before install. You should be able to tap it in with a rubber mallet after that.
newrider3
Colorado
I guess I should've been more specific; it needs to be pressed onto the crank. How should I heat the bearing without damaging it?
Kaptain Krunch
Pro Junk Collector
vermont
Try sticking the crank in the freezer over night and then try, you may be able to safely heat up the bearing but I have no clue. Or you could just bring the crank and bearing to a machine shop and they could do it.
jr dragster T
Cold place
Heat the bearing at 400*F in the oven for 10 minutes and chill the crank to about 25-30*F. The bearing will almost slide on but move fast because you only have about 3 seconds to work with it. Ensure there are no burrs anywhere on the crank/bearing and apply light oil to the crank where the bearing will slide on.
newrider3
Colorado
I can't really do it with the crank out, because the cam gear ends up sandwiched behind the bearing. I'll see if I can't jam the whole thing in the freezer for a while..
Wait, it is -18* outside. Screw the freezer haha.
