only if you hit it with a hammer while its spinning 10k with holes drilled in em.
Not true, there have been deaths caused by flywheel explosions, and it doesn't have to be 10,000 rpms either. Some flywheels will take a lot more rpms than others. My GX 240 will turn over 6000 rpms with a completely stock valvetrain and stock (jetted) carb. It's got raised compression, a header, high flow air filter, and advanced flywheel key, that's it. Unfortunately, they don't make a billet flywheel for these GX 240 motors, or I probably would have bought one. They are lighter, (good for quicker acceleration), and much safer than a cast aluminum or cast iron flywheel. If you build a motor capable of more than 5500 rpms, you should be
thinking about a billet flywheel, 6500 or more, it should be on your
want list, 8000 or more,
better not run it hard without it. Don't say you weren't warned....
